Reinell open bow with force worth.
oregonboatnewb
Hey guys, still hunting for a good tri hull open bow... found this today, guys is only asking 1000, and i'm sure i could knock a few hundo off it, sounds like he wants it gone sooner then later... his brother "redid" the floors 4 years ago, its been under cover since every time they take it out... I'll put up more picts when i get them from him.
He wanted to say the boat is around a 78 and motor mid/late 80's... does that look about right?
http://seattle.craigslist.org/tac/boa/1018687635.html
ondarvr
Re: Reinell open bow with force worth.
I would be worried about the floor, redone probably means new plywood slapped over the old stuff, but other than that it may be OK. Check it for rot unless you want a big project.
If you can get it for a little less it'll make up for the main motor being a Force and the kicker is a big plus.
tashasdaddy
the best thing about that boat is the johnson kicker. it's worth more than all the rest put together.
eaglejim
Not a bad looking boat if it not in to bad of shape and get them to knock off about 400.00 you will be ok I think
mrcool
Seems like a good deal if you can get him to take less, The Force motor isn't worth much, but the Johnson is:D
oregonboatnewb
i found a guy on CL that does floors for boats, and paid him 20 bucks to check it out, said the floors were not marine wood, and was fully dry rot under...
No go, but i found another.
