111KAB
Thread starter- Joined
- Aug 11, 2009
- 7
Good morning (in UK!)
I have been having battery/stator problems with my 50hp Mariner 2 stroke outboard - see the thread ......http://forums.iboats.com/showthread.php?t=507791&p=3418551#post3418551
It appears that I may have been using the wrong type of battery for my engine as I have been using a maintenance free battery rather than a wet cell one. With the power my engine/stator is putting out this has 'cooked' my current battery. In order to get over the problem (apparently) I can either get a wet cell battery (recommended) or I can incorporate a regulator spliced into the electrical feed from the stator to the battery and then use a maintenance free (car) battery ~ in other words either battery can be used. In would prefer this possibility ie the ability to use ANY 12v battery.
Firstly thanks to John Martin for his help on the above mentioned thread, secondly my only trouble now is where do I get a reasonably priced regulator (12v - 20 amp?) and which wire do I link it into.
Thanks for your continued help
KAB
KAB
