I have been trying to find a new prop for my Regal 2200 and wanted to see if anyone with the same or similar boat can share what they are using. Below are the details for my boat & the different props that I have tired. I don't know if there is a perfect prop out there, but wanted to see if anyone has recommendation. All the props listed below run a bout the same WOT (49-52 MPH at 4900-5000 RPM.
Boat Details:
2003 Regal 2200
350 mag MPI engine
Bravo 1 out drive (1.5 ratio)
Props Tried:
Solas Rubex 4 AL prop 17P - Runs good, but to much bow rise and not a lot of grip in corners. After 1 season the prop shows a lot of cavitation wear.
Solas HR 4 SS 16P - Prop runs very nice, quick hole shot, but you can hear it makes the motor work harder. Slightly noisey at low RPMs.
Powertech SFS 4 17P - Best overall prop, easy to turn, quick hole shot, can not get trim the bow down as far as Solas HR4 in copy water. I also really like the powertech cushlock hub (Very quiet).
Boat Details:
2003 Regal 2200
350 mag MPI engine
Props Tried:
