refurbishing poontoon boat
rlcrews
i am planning to completely redo a pontoon boat i have . it needs it all carpet, furniture , console , needs live wells sound system etc, etc.
i will also be looking at getting a new boat instead . new boats i have already looked at start at 40,000+. which is a little out of the budget range.
i realize that i will still have an old boat that looks new but it will be payed for . that being said if the refurbish ends up being to high will opt for the new .
so i need recommendations on where to shop for the new stuff .
MH Hawker
Re: refurbishing poontoon boat
You can find lots of stuff easy. I rebuilt mine last year. Yes you can drop 40 k on a new one or rebuilt it for a lot less and get exactly what you want.
Bamaman1
For pontoon items, pontoonstuff.com is a great place to go.
Nothing wrong with an older pontoon boat. That said, I would only want to rebuild my pontoon boat only if it was mechanically sound. In other words, don't spend the $ for seats, etc. if the engine's not worthy of being on a boat of substantial investment.
And you don't have to do it all at the same time. Rebuilding can be done in stages if it's too much $ at once. I see people all the time with folding chairs on their toons.
Cubbyblue22
There are so many websites i've found as i've been re-building mine for the past year and a half. Pontoonstuff Pontoonspecialists EverythingPontoon RestorePontoon ********.....the list goes on and on. I've found it's a lot more fun rebuilding a pontoon from the ground up rather than just buying one because everything you do is your work and your decisions. Have fun!
rlcrews
hey guys have a couple of new questions.
first of all thankyou for all the info so far . have found many new sites as well as looking here .
1) , are there a difference in marine grade plywood flooring versus the treated plywood you find at lowes or home-depot ?
2) would you go back with carpet or vinyl on floor ?
3) i am trying to find a captain console with a sink included as i have seen on the newer models i see at the boat shows. are these not available or are they a separate unit ?
4) need to pickup a high quality porta potty . it needs to be able to support the heavy weights (250 - 300+) . also needs to be easy to deal with as far as cleaning , and emptying , should also be similar to a home unit as far as height. (girl friend has limited flexibility from knee surgery .
5) and last question for now (lol) i have also looked for inclosures half as well as full . does anyone offer them or is this strictly custom item only ?
MH Hawker
Ok lets go down your list
Yes a lot of difference pressure treated plywood will dissolve the alum cross members. So don't use that, marine grade will last 20 years
Both will work fine , a lot of people are going with the textured marine vinyl with good results.
Not sure but I think those are separate units.
Not sure on that
Thats a bimni top and most of the full type enclosures and custom made to fit.
rlcrews
thanx for the reply . and what a dummy i am . i install vinyl siding and use coil stock and new about the alum. issue you mentioned
i bet the marine grade cost twice as much .
MH Hawker
Yea it aint cheep it runs from 50 to 75 a sheet depending on where your at. but after a year or 2 of use you arnt wondering if your gona fall through the deck.
