Reed valve condition?
wavefisher
Hey guys, just wondering how well reed valves are supposed to work? I have a 1979 70hp 2cycle triple cylinder evinrude. At idle feul will slowly build up in the carbs but when reved a little it seems to suck it in. Maybe this is why there is that drain tube in the bottom of the intake housing going to the crankcase I think and maybe that's part of the reason 2 cycles "load up" at slower speeds? Or should there be zero blowback thru a carb at any speed?
I have an older '75 Johnson twin cylinder 50hp that actually spits a little gas out of the upper carb, this I think is too much and wow it seems to be awfully hard to find reed valves for older engines
emdsapmgr
My 96 70 hp engine spits a tiny amount of fuel out of the top carb. That's normal. The engine's lube system for the crank is designed with a small hole in the intake manifold right behind the top carb. When running a small amount of fuel/oil will spit back thru the upper carb. That's normal. You won't find much fuel/oil accumulation in the airbox cover, but yes, the drain at the bottom of the airbox does recirculate any unburned fuel back into the bottom cyl. where it is combusted.
gm280
Actually some times those little tubes supply fuel/oil to the main bearings so they get lubed while running. So it is more for lubrication then excessive fuel draining. If you carb(s) load up while idling or slow speeds, adjust the low speed adjustment screws on the carb(s) to solve those issues. JMHO!
wavefisher
Ok thanks for the education guys! I don't think I'll rush out and buy new reeds, if I could even find them
gm280
I honestly have to admit, I am anything but an expert on 2 cycle engines, but I've been reading these forums for a few years now and I have yet to see or read anybody replacing reed valves for their engine problems. In fact I've yet to read of anybody replacing their reed valve for any reason... JMHO!
Honorary Supreme Mariner
Have a 9.8 Mercury apart right now and reed valves are chipped / cracked.---Going to put in a new set at some $50 for the set.
gm280
racerone, somehow I knew YOU would post something to the contrary. But how many threads on these forums have ever talk about reed valve being their problem?
boobie
Racerone, but that's Mercury. The old ones were known for that. :sorrow:
