Charliecee2002
Thread starter- Joined
- Feb 18, 2006
- 25
Mine is a 9.9 evinrude and it spits bak out the carb. reed damage??/ can i fix the reed????? the fuel float tank won't stay full. fuel pump???<br /><br />thanks<br />charlie
Originally posted by Chazndee:<br /> actually it doesn't run when i throttle up it dies and i have to squeeze the bilb again and restart it. it tries to idle awhil and the eventually dies. spitting out of the top front hole of the carb when i squeexe the bulb.<br />charlie
Sorry about the double post. From your description I doubt any reed damage. Do a complete carb teardown and a thorough cleaning. I recommend a good, several hours, soaking in carb cleaner then rinse parts with aerosol carb cleaner and blow out with compressed air making darn sure every orifice,passageway and metering jet is sparkling clean. Re-assemble with a new carb kit and give her a try.Originally posted by Chazndee:<br /> actually it doesn't run when i throttle up it dies and i have to squeeze the bilb again and restart it. it tries to idle awhil and the eventually dies. spitting out of the top front hole of the carb when i squeexe the bulb.<br />charlie
