I was just looking for a way to reduce slip on my boat. I have a Spectrum 1804 Aluminum bass boat with a 175 Suzuki motor. The boat does have rivets on the bottom of it and the deck is plywood. I run with light amount of equipment and looking at about 15% slip at WOT with 2 guys. Is that good? Could it be better? I am running a Turbo 2+2 26". Motor is up as high as it can go without braking loose. Shaft is 5 3/4" from V.<br /><br />A basic run down of the equipment I run on board:<br />2 batteries (placed about 1 ft back from the driver/passenger seat...not all the way to the back)<br />5 rods<br />1 tacklebox<br />2 anchors (15lbs a peice)<br />a couple of tools<br />2 lifejackets/2 throwables<br />1/2 of a 15 gal tank (normally)<br /><br />boat weighs 1024 lbs stock.
