fireman57
- Aug 24, 2004
- 3,811
I have an '83 evinrude 50hp that someone has cut the red plug from the engine off of. I got a used one from a marine salvage yard but it has two black with yellow striped wires and from the engine I only have one. Do I add wire to one of them and make sure that both are grounded or do I just use one of them.<br />I also have a brown wire coming from the engine and the new plug harness has a very faded white wire that could have at one time been brown. Is this for an alarm and does it need to be hooked up to keep it from going off if it isn't?<br /><br />If I remember right it is:<br /><br />Red w/ purple 20 amp fuse<br />Purple w/ white primer solenoid<br />purple battery voltage in run on ign<br />Black battery negative<br />black w/ yellow kill switch<br />Yellow w/ red starter<br />gray tach<br />brown alarm?<br /><br />The black w/ yellow goes into a plug that I cannot find on ishopmarine. Is this the starter switch that brp evinrude shows?<br />Thanks
