RECTIFIERS
ROTTYRAS
HOW DO YOU KNOW IF ITS GONE BAD WHAT KIND OF SYSTEMS HAPPEN IF ANY KNOWS
Coolmaker
Re: RECTIFIERS
It won't charge if the rectifier is bad. <br />12 volts with the engine running (bad)<br />13.6-14.2 volts with the engine running (good)
jonah 65
Re: RECTIFIERS
connect red lead of ohmeter to ground, black lead to alternator terminals (1 at a time)meter should show continuity, reverse leads and repeat, meter should show no continuity. connectblack lead to positive terminal, red lead to alternator terms. (1 at at time) meter should show continuity. reverse leads and repeat, meter should show no continuity. all wires to the rectifier must be disconnected before testing.don't forget to disconnect battery first, and reconnect rectifier wiring before starting engine. make sure to connect battery right way round.
