Rectifier/Regulator Output
boatmon345
Working on 1997 Yamaha 150HP Salt Water Series II S150TXRV 2 stroke 6 cylinder powerhead.<br /><br />Coming out of the rectifier/regulator, among other wires, is a red wire with a 30A fuse and then terminates to nothing. <br /><br />It seems that this wire could go to a secondary battery to charge it. Is this correct? And if so, by charging a second battery this way would the second battery be, in fact, isolated from the primary battery?
Texasmark
Re: Rectifier/Regulator Output
No idea. Why don't you www yammie and ask. Could be that, or an accessory drive source.<br /><br />Mark
rodbolt
yep. its for charging a house battery.most yamaha v6's since 96 or so had it. its called a battery isolator circuit.<br /> if its not used its capped.<br />as far as isolated it depends on who wired the second battery and any parralel circuits that have been introduced.
boatmon345
Thanks RB. I think I'll remove the parallel circuit to my second battery, and then connect my second battery to this lead.
