Rectifier question
emptycooler
I hAve a 2001 johnson, 25 pull start , i installed a rectifier on it, hooked it to battery, it charges fine, but after about a weak my battery went dead,do I need to disconnect the rectifier from the battery when I'm not using the boat, as of now the wire is unswitched, thanks.
schematic
nope. no need to disconnect. Battery likely going dead because of other drains on the system, or even a bad battery....
F_R
Honorary Supreme Mariner
A disconnect switch in the charging circuit would be a bad idea. It would only add a possible trouble point. Anything that breaks the path between the rectifier and battery while is is running will kill the rectifier. Furthermore, it is the rectifiers' job to prevent backflow from the battery to the stator, as you are suspecting.
gm280
Well first you need to check the rectifier to verify it is still good and working properly. If the rectifier you installed had any portion of it go short, then yes it can drain your battery. So check that first before buying another battery. I also suggest you separately charge the battery and have it tested at a local auto parts store to verify it is good. A standard engine rectifier is merely a few diodes connected in a way to convert the AC voltage coming from the stator to a pulsating DC voltage going to the battery. So if any diode shorts out, it does effect the charge capability of the system. JMHO!
emptycooler
The battery and the rectifier are both new, I also keep the controller for the power driver trolling motor under the bow with life jackets, dip net ect, somethingay have laid on it,it was dead,like wouldn't even make my running lights light up dead
Crosbyman
new does not mean good.... you can always try a radio shack rectifier. The little square ones go for abaout $5 and are good for 25 amps
connect the 2 stator AC wires were indicated (sine waves) ... the + to the battery and the other pin to ground
bolt it somewhere to heat sink it
