Re: Rectifier Question
Laddie, Thanks for keeping up with the thread. I realy appreciate your help. my engine is a 85 50 hp 4cyl. I'm using the CDI toubleshooting guide for the 4 cylinder. I'm really stuck. I'm not sure what would cause the rectifer, low speed stator coil and the brn-black coil on the trigger to go bad at the same time. I thought the trigger wire problem would fix my problems, but no luck. my original problem was that I had full power in neutral, but would only go 10 mph at wot. I rebuilt the carbs and pump, but same problem. it was hard to start, but it started. The very last time I started the boat, it had been sitting for a couple months and I hooked my battery charger to it. I may have screwed up, I set it to the starting setting on the charger, high amps and hooked to my battery. it started, ran rough, stalled out and has not started since. I'm guessing I fried something. I bought a new battery before I started this round of troubleshooting. The strange thing is, it was an old battery charger and when I tried use it last week, it was bad to and had to replace. My latest question (thanks for your expertise and PATIENCE) would the 20 amp fuse in the starter wiring have blown if battery charging setting on the battery charger was set to high? Also, is there a wiring harness on a 50 hp merc? Is it in the control box that has the key? Thanks again for your help.
mark
