MassillonBuckeye
- Jul 26, 2010
- 400
Re: Rectifier already bad?
Rectifier is indeed good. Maybe that #1 coil not sparking was the reason my tach wasn't working.
The first testing method I posted, which also seems to be the most common one found online, is also flawed. Its results tell me that my good rectifier is BAD. Use the second method I posted.
Recap:Bought boat, tach not working. Rectifier fried. Replaced rectifier, tach works, motor running bad. Tested rectifier as per what looks like Aftermarket service manual, and tests bad(1 week old). Purchased OEM Service manual, rectifier tests good with this method. Also diagnosed bad coil pack and replaced. Tach now works!! but is about 200 RPM off. It doesn't seat on zero but at about 200.
The bum coil was throwing off the tach? I still don't know why the first testing method posted in this thread says my GOOD rectifier is bad.
Here on iBoats they sell Teleflex which are good. Make sure you get the two stroke model.
