Recommended grease for trim pump wiring ends
FLANDY
I will soon replace my '06 AlphaOne GenII trim pump bracket with a new SS bracket. While at it, I will sand and shine all the corroded wiring ends. Can someone recommend a good grease product for this project?
timing_ca
Re: Recommended grease for trim pump wiring ends
I use dielectric grease use it on my big rig and stops alot of corrosion from water and road salt and the new brine there using. Don't be shy when you put in on.
superbenk
You can also get liquid electrical tape that just brushes on over the contacts.
achris
More fish than mountain goat
Merc do a great product for that, Corrosion Guard. Just spray it on, it dries and seals against water.
Ayuh,.... Welcome Aboard,..... 'bout Any grease that's in yer grease-gun will work, Just Fine....
