Please bear with me, I'm a bit of an audio n00b...
A buddy of mine gave me an enclosure with two 12" subs and a 600 watt amp (this one: Coustic 601SE 2 Channel Amplifiers at Onlinecarstereo.com) that he wasn't using for his car anymore, and I was planning on ditching the enclosure and mounting the subs under the rear bench seat in my Four Winns Sundowner, but unfortunately I found out once I got the boat out of storage that I only have about 10.5" of height to work with, which pretty much rules out any subs (even 8"), since all said and done they are too large.
So now, I'm thinking that an 8" Bazooka tube ( this guy: Amazon.com: Bazooka MBT8014 8-Inch 4-Ohm Marine: Electronics) might just fit perfectly under the rear bench, and I could still use the amp he gave me to power it. However, I'm wondering;
1) would a 600 watt amp be too much power for that tube? It says its power handling is 150 watts. If so, perhaps I would be better off going for the internally amplified version of the Bazooka Tube, and ditching the amp...?
2) Would an 8" tube in an enclosed space under a bench give me a worthwhile boost in bass?
This is the bench I'm talking about:
Also on another note: I'm currently running 4 6" Fusion speakers, two topside and two in the cabin. I'd like to add two more 4" Fusion speakers topside, and amp the 4 topside speakers. Any recommendations on a 4 channel amp that would suit my application? I'm on a bit of a budget so the cheaper the better, but I don't want crap quality either.
Any advice is appreciated,
Thanks!
Thanks!
