Recoil gear replacement HELP?????
mettyfish
I just bought a cherry 10 hp 1976 Chrysler motor. Does not look like its been run since about 1977. I ordered an impeller for it and the last thing needed in which I ordered is a recoil starter gear. The one on it it is broken. I noticed the little spring that hooks up underneath it had come off so I guess previous owner tried to start it while running. Anyway, I don't want to have to take the whole pullstart assy apart. How do I change the gear only. Does the pin it rotates up on slide out? And I will have to undo some things to pull it out from under the fly wheel also. I would appriciate any advice before the surgery. Thanks, Metty
