I'm rebuilding a Tillotson Carb from a 1973 Chrysler 6hp model 62BD. The carb has the numbers 429061 and C06A 7 in it.
The motor was running fine, but when I used it last time, I ran it dry. When I ran it today, it started up fine, then died quickly. There was gas leaking from the carb, so I suspect I need a new needle and seat. I'm trying to take the carb apart so I can inspect the needle and seat, but when I attempted to do so, I found that the pin that holds in the float bowl is unwilling to come out. I've tried heating it with water (don't want to use a blowtorch this close to the plastic bowl), but the pin won't budge. I have tried persuading it, tapping it with a hammer, pulling on it with pliars, but all I am doing is scratching the pin - I don't want to keep hitting it with a hammer, as I suspect I'll break the carb housing.
Here's a picture of the pin.
Any advice on how to get this out?
