alfajeffrey
Thread starter- Joined
- May 4, 2015
- 7
I am in the process of rebuilding a 50 Hp Johnson J50BECOB. I bought a used powerhead, but I haven't gotten it installed yet. The motor had been disassembled previously, and the person used some type of thread-locker to reassemble. That had resulted in me having to dissemble the entire motor to get some seized bolts out. Now I have it all apart, and I am waiting on some gaskets for re-installation. I have a few questions that I expect I will need some guidance on.
The shifter rod that runs down the motor to the lower unit, needs to be screwed in once the motor is reinstalled. How do I know how many turns to thread that rod in? Should I just set it in Neutral, and then turn it until it lines up with the linkage properly.
The second question is which wire is for the top coil. One of the signal wires has a blue stripe on it, and one has no stripe.
THe thrid question is about the wire comin out of the head. it has a unique spade connection. The connection looks like half a spade, bent over. There is a second similar connection on the wiring harness, but i don't understand where they go.
Any advice will be great.
Also torque specs for, the bolts connecting the midsection to the powerhead; as well as the flywheel nut.
