Don Hansen
- Sep 17, 2007
- 230
I have a 1970 and a 1974 Evinrude 4 hp power head. Both power heads have bad cranks and the 1974 threw a rod putting a hole in the carb side block half. Not surprised at the 70 as it has many many hard hours on it. Have know idea why the 74 blew a rod because the motor has very few hours on it. The cross hatch can still be seen on the cylinder walls. What I would like to do is use the carb half of the 70 block and the cylinder half of the 74 to build a working power head. Both part numbers are the same so I was wondering if that would that work? Or should I look into having the damaged block welded. Also, I noticed on the 74 crank that the needle bearing is packed with grease while the bearing on the 70 does not. Did they come with grease from the factory and it's eventually washed out. I have the manual for the 70 and it doesn't say anything specific about lubing the needle bearing.
Don H
Don H
