Well, the story I was told is that this motor was out about 1/2 mile from start point running WOT when it slowed and died. Since that moment the motor was hard to pull through.
The carb tear down revealed a piece of debris made it past the filters and clogged the main jet. Tore down the carb, dipped it, rebuilt and tested.
The motor is hard to pull through when cold, but once started any consequent starts are easy to pull. Idle is rough, acceleration is smooth and strong and high end is strong.
I've got 100psi compression on top and 120 on bottom.
The one thing that nagged me was that every time this motor cooled down it was hard to pull start. So, I decided to remove the exhaust manifold and see what I could of the piston/cylinder condition... Not good. I included pics, I'll probably end up tearing down this motor to find out all that's wrong and fix what I can (provided it's not too ridiculously expensive.
So, the point of this thread? Speculation.
First, what do you guys think the real story is, how bad do you guys think the damage is going to be, and how much will it cost for the DIY to complete?
