rebuild carbs
llgohde
Does anyone know if f60 yahama 2004 can be rebuild and if so some one i can send them to have it done?
robert graham
Re: rebuild carbs
Most any Yamaha boat/motor dealer should have a mechanic to clean and adjust carbs.
Capt Ken
Re: rebuild carbs
Rebuilding them is easy, balancing the intake vacuum is going to be a problem without the proper equipment.
Bamaman1
Re: rebuild carbs
As long as the mechanic is careful, no carb kit is even required. It's easy to clean most any 2 stroke carb--just a few minutes to do each carb.
