Kickin Bass
Thread starter- Joined
- Aug 31, 2003
- 4
I have a 1980 35 Evinrude with 90 compression on the top cylinder and 110 on the lower. I suspect ring wear or slight seize or a stuck ring.<br />Before the compression check I replaced the plugs and ran the motor for about half an hour. I checked the plugs and the lower was a nice brown color but the upper looked like it was new with absolutely no color.<br />Both plugs have a strong blue spark. The motor is hard to start, won't idle and runs real rough.<br />Should I do any other diagnostics before tearing the motor down? I am planning to go over the entire motor from top to bottom to ensure that it will be reliable. What should I pay particular attention to? What should be replaced regardless of condition, reeds? impeller? crank seals? bearings? Are there any mechanic tricks I should know about? <br />Thanks in advance.
