Rear Motor Mounts bushing R/R
series60
Haven't seen much about R/Ring the rear motor mount bushings.
Would like to know the easiest way to r/r these bushings for my application as noted in my sig. Everything is on the work bench.
Bt Doctur
Re: Rear Motor Mounts bushing R/R
Use heat to burn the center out of the rubber,
Use a socket to drive remaining part from housing or a small screwdriver to remove the metal shell.
clean the hole
install new spacer
using a socket to fit the shell and a press or "C" clamp install the new bushings untill seated.
The item pictured I made to install bushings.the upper part has a relief that is a slight press fit in the housing, the lower part has a relief to sit on the outer shell part. install the spaced untill seated, start the bushing STRAIGHT, tighten thereaded rod untill seated.
PM`d my cell if you have questions.
series60
clean the hole
install new spacer
Thanks Doc. That's got to be a $100.oo tool you made there! Got to consider this some more. This one is going to be a gut call!
