JB
Thread starter- Joined
- Mar 25, 2001
- 45,907
ESSENTIAL DATA REQUIRED
When posting a question about propellers, you cannot get a reasonable answer unless you provide the following information in your post: Items 1-4 are essential for meaningful response to most questions.
1) Performance issue you are trying to correct.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
3) Current prop diameter and pitch (required).
4) Wide open throttle RPM and speed with an average load (very helpful)
5) Engine/drive make, model, year, and HP
6) Boat make model, year, length and weight
The below link would be a much more thorough list of data to provide if you're looking for detailed performance numbers,
http://forums.iboats.com/prop-quest...op-bravo-3-gear-ratio-353545.html#post2336620
