Decided to pull all the old guages and replace with shiny new Teleflex ones. Since I am doing this, I figured I would just go ahead and rewire everything since the boat is 20 years old.
Question, can I use something like this? And is 14/2 gauge acceptable to use?
http://www.iboats.com/14-2-Flat-Dup...8924393--**********.049638140--view_id.165804
I realize I will need some separate wire for the grounds. Will get single wire for that in the same gauge.
Also, There is no fuse box on this tub. I assume that would probably be a better option. If I go that route, what gauge would the single wire from the box be to the back of the tub?
Thanks in advance.
Thanks in advance.
