re wire trolling motors from 12 to 24
igotskills
Does any one know if I can rewire my 12 volt trolling motors to 24v?
They have 4 wires, one of them obviously a ground. When I put juice to the others it makes the prop go faster or slower, what would happen if I put juice to all of them at the same time?(except for the ground of course)
Barnacle_Bill
Re: re wire trolling motors from 12 to 24
What trolling motor are you working with? If its a 12V TM, then your answer is no. But from what you are saying it sounds like something is or was a 12/24 TM.
Silvertip
Honorary Supreme Mariner
Are you saying there are four wires between the trolling motor plug and the head of the motor? Never seen that although some boats were wired with four wires between two batteries and the connector panel at the bow. Two wires were intended to connect to each of the two batteries but that did not necessarily mean that was a 24 volt system. It could be EITHER a 24 volt (series) system OR a 12 volt parallel system. Normally there would be a switch on the troller pedal or the receptacle panel labeled 12/24. But if you have a 12 volt motor you cannot run it on 24 volts. It will burn it up. We need more information on what you really have and what you are attempting to do.
