gregstukey
- Jun 25, 2006
- 56
When re-sealing a drive, is it necessary to pull the whole drive apart and re seal even the bearing seals? or is it just a few critical locations that must be addressed (and where might they be on a Volvo sx drive?)
Also, I have a customers pinion bearing housing that siezed in the pivot housing actually severing the pinion bearing housing at the 4 bolt holes upon drive removal.
Can I rebuild the pinion bearing housing using the old input gear shaft? Should I use what I can from the old set-up or build new from scratch? If i do rebuild from scratch can I at least re-use the input gear to avoid having to change the other corresponding gears?
and I have to do this x2 on a neglected salt water chris craft with Volvo SX drives.
