barryll
- May 5, 2007
- 58
Re-riveted leak (structual)
1997 Starcraft Fishmaster 190
I found 14 leaky rivets last spring, drilled them out, sealed with 3M5200 fast cure, and re-riveted. Rivets used were 3/16" aluminum eyelet, coated steel mandrel, blind rivets and used a pnematic gun for the pull. Just floated the boat (still strapped to the trailer) to look for leaks and found 6 of the repaired rivets were leaking again. The good news is I thought I had a crack in the apoxy down the keel but I hope its just rivets. The bad news is what did I do wrong. Should I have went with a 1/4" ? You can see the rivets I repaired running down the left side of the picture. Any theories out there?
Thanks in advance,
Barry
Thanks in advance,
Barry
