imported_74baja
Thread starter- Joined
- Feb 14, 2007
- 47
Hi all,
I have a 1974 16' Baja speed boat with a 1999 Johnson 115. Currently my wheel is an 18 pitch Raker. On my last run this year, I cruised along for a while, but ever since getting the new motor (old one was a '74 115 shaft rated hp vs. prop rated with the new one) I couldn't help thinking that I feel like I'm going to slow for higher rpms, however, ever since I did the transom replacement, I haven't gotten around to hooking up the speedometer. So, on the way back, I hit it and saw the tach hit just over 6k with some throttle still left and I backed off. So, since the recommended is 5-5.5 k I figure I should prop up a bit. Also, I was thinking of raising the engine up a hole, since the cav plate is just about even if not slightly below the keel. So, I guess I'm wondering if it makes sense to bring the prop to a prop shop and see if they can re-pitch it, or get a new prop. My current prop is not in excellent shape, it has one 1/4 inch ding and a few smaller ones (previous owner). Can a prop shop repitch the prop my guess of about 1-2" that I will need, or does it make sense to get a new prop? Also, I have not been able to find any sites that sell raker props, are there any?
Thanks, sorry for the long post,
Jack
Jack
