re 85 hp overheating
luckyman1
Ok guys im at the end of my rope.i took out lower unit twice, impeller was like brand new. Pulled thermo and tested, ok. getting water to head through tube. But not when l.u. is reconnected. Is it in the prop housing where the screens are? That's gotta be it isn't it? And do I need a puller to get that out? Please help Im tying the knot as we speak. Just kidding about the knot...This is frustrating!
MickLovin
Master Chief Petty Officer
Re: re 85 hp overheating
Ok you say you aren't getting any water from the lower unit, try putting a hose up the water tube coming from the mid leg to the LU, you have to have the LU off and if you look up there will be a tube thats feeds the water to the power head, also is it a chrysler or force you are talking about and what year nodel is it.
I had a similar problem with my 75hp chrysler and this fixed it, as it had sand in the water tube clogged from being beached.
luckyman1
Yeah I did run water up the tube it was fine ,its got to be in lower unit.Thanks for reply .tomorrow I will be pulling apart prop housing.
MickLovin
Have you made sure you put the impeller in correctly, sometimes you can put it in wrong and will not pump correctly. otherwise put the lu in water and see if you can turn the shaft and see water coming out of the pump. If you don't have one get a manual more than worth it for these old motors.
Jiggz
If you verified water is getting to the head and out the snout, then it is definitely the LU. Make sure you are installing the impeller properly and using the correct one too. You can double check all the water passages in the lower unit after you removed the impeller housing and make sure there are no blockage. Re-assembly is critical so make sure the impeller housing is properly aligned with the water tube in the mid-leg.
Conduct test using muffs instead of barrel or lake just make sure you regulate the faucet pressure just enough. For now remove the t-stat and replace cover. Run motor and you should see cooling water exiting the exhaust snout, if not check the muffs make sure they are centered to the water inlet of the LU or better yet hold them in place for a few seconds and you should see water exiting the snout, if not shut down motor. There is serious blockage or the impeller is not correctly installed, incorrect type or the water tube is not aligned with the impeller housing outlet.
However, if water is exiting in the exhaust snout continue running in fast idle to see if motor overheats, 2-3 mins should be OK. If not, shut it down and re-install t-stat (on some models this can be installed backwards while on others it cannot for it will only fit one way, but if installed backwards motor will surely overheat because the sensing side of the t-stat is facing away from the cooling water). Test again, while making sure cooling water exits the snout as soon as the engine starts. If motor overheats, check the t-stat installation is correct.
MickLovin
Have had personal experience with a PO putting in a t'stat reverse and I wondered why it would only heat up at half to wot.
jerryjerry05
On his motor.Don't think the right thermo can be put in backwards???
Post some pics of the pump, the housing, the impeller.
Sometimes the little connector on top of the pump gets knocked off?
Sometimes the seal on the drive shaft pops out?
luckyman1
Thanks jerry.So i pulled impeller pump off now how do you get the plate off under it ?Do i have to pull prop and seal behind it?Going to get manual today.sorry for being dense.
luckyman1
Success! ,got er done guys. thanks a lot for all the info. put in a tell tale along with new impeller and she is spittin water all over the place.goin out this weekend to hunt some marine wildlife.yahoo.
scottmm73
What was the issue? I guess it was the impeller?
luckyman1
Yeah sorry it was the impeller apparently.Or the water tube wasn't aligned right.anyhow, its working good now.Thanks for all the input guys.
