John the landlubber
Thread starter- Joined
- May 13, 2005
- 146
I am trying to cure the popping back through carb/misfiring and have taken the carb off. I will clean that out with carb cleaner and blow it all out with air. I took the reed plate off to examine the reeds which seem to be fine. When I look behind the reed plate into the crankcase I can see two ports (each with an alan key type nut) is this the bottom end of the caps and should these ports have a red powder/spray like substance in them? Also, can I carry out a compression test with the carb and inlet manifold off or do I have to put it back on to get an accurate reading? Do I have to replace the gaskets either side of the reed plate even if they look to be ok and do i need to replace the head gasket if i take the head off? I need to get an impellor kit but am hoping to swap my lower unit to long shaft. Can anyone tell me if the kit is the same for both? I am hoping to get this kit and a carb kit from sierra but am struggling to find a direct website, or do i have to get them through a dealer? Any help gratefully received.
