SamShapiro
Thread starter- Joined
- Sep 6, 2021
- 3
Hello! I have owned a 19 ft runabout for the past year and in the past few weeks there has been a knocking/rattling noise that has gotten worse and worse. It is noticible at idle, and is deafening at any RPMs above idle (see attached videos for idle & about 2500 RPMs).
The boat was recently in the shop as the starter motor had been acting up (ended up that it needed to be tighted as it had loosened itself), and the belts have been recently changed, non of the pulleys on the alternatator or the water pump make any noise themselves. I also pulled out the mechanical fuel pump as knocking/clicking seems to be coming from that general area, I have the picture of the fuel pumps mechanical trigger attached - not sure if the wear looks normal.
I am a bit perplexed as to how to being diagnosing and would love some advice!
Thanks in advance!!
Thanks in advance!!
