Hey OBJ, or anyone else with experience, I got to foolin around with my motor again before getting rained out (again). I'm still getting lack of spark after changing the coils out. I've got the wires fully seated and every nut and bolt tightened and cleaned up, and the grounds from the part the coils mount on cleaned up and the grounds to block cleaned up. I did replace the wire on the starboard side that grounds from the sideplate to the lower cowl, the wire was cruddy like a corroded old battery cable. Is it possible that the other ground wires may be in similar condition also? I also pulled the powerpack off and wiped it down and looked it over and noticed it's a Rapair(ed) powerpack, the date mfd was 6(month), 1(week) and 0(year). Is that from 1990 or 1980? It's just funny that it fired up with no problem before bustin out some new coils and now I get nada.....one more thing I turned the motor over for about 8-10 seconds and it tried to fire weakly a couple times. I'm running out of the simple things to look at before getting into more complicated tinkering. It is getting fuel the plugs are wet and I could smell the gas when plugs were out. The jury is still out on looking into the kill switch itself also...<br /><br />1977 V4 Rudi, 85 horse 85799S
