sixfingers
- Sep 26, 2006
- 13
Re: Ranger live well problems
OK, I have an update...FINALLY! lol The weather amongst other things have been holding me up, but I finally got everything put in, minus a new toggle switch for the pumps.
Here we go...This first pic shows what was in the boat originally, after removing one of the battery's
Very messy! Note the one pump attached thru hull, with a T adapter splitting the water intake in order to fill both wells. You can also see the drain line's are also T'd for both wells, and only ONE overflow going out from the rear live well. The front live well just overflows into the bilge :devil:. Nice garden hose too!...lol
Here's a pic of the front underneath the floor. Stuck the camera through the drain hole and snapped a pic so I could see what was going on in there.
That pipe to the left is for the aerator. On the bottom the drain, and to the right the overflow pipe, with no hose attached. Great way to sink to a boat! Anyhow, I went to Lowe's and found some PVC that would fit the overflow pipe, and attached some new hose to tie it into the rear live well overflow. Now its all going out the back.
Original front live well aerator and very dirty tank.
Just a cap screwed on the PVC with a notch cut in it. (twisted so you could see the cut)
Here's the new flow rite power stream aerator.
Simply screwed off the original cap, put some fresh Teflon tape on the threads, and screwed the power stream aerator on. Also cleaned the tank as best I could with some softscrub. All done! Same process in the rear live well...(don't have a pic of that one.)
Original Ranger actuators...
Flow rite version installed.
I fabricated the plate out of thin plywood, and shaped it bit. Didn't like the square look. Might move both pump switches to this plate also.
Here's the new pumps and valves installed.
Ignore the mess of wires, I intend to straighten that up. It took a bit of time to figure the layout of all this. I layed out the pumps/valves, and attached the actuator cables to the valves, and moved them around until I knew I could make all the hoses attach and go where they needed to, without any kinks. Once I knew where I needed them, I epoxied some small platforms to bolt the pump/valves mounting bracket to. Those little white blocks in the pic (actually you can only see one near the top of the pic) are a plastic/nylon type of material. Easy to put screws into, and won't rot if they get wet. Anyhow, once that was all dried, I just ran my hoses as needed. (BTW, you don't need the crimping tool if you get the quick lock attachments. I just used a pair of wire cutters to crimp those rings...worked great!)
The overflow hoses are clear so its hard to make them out, but I t'd both wells to one thru-hull fitting. Both pump's/wells have their own intake now.
Here's the back of the boat thru-hull fittings with new screened strainers. 4 holes in all...Two water intakes/drains (the screened strainers), lowest hole-bilge drain, and overflow drain at the far right.
They just snap right into flo-rites thru hull fittings. All I have left to do is install a switch for the new pump, tidy up the wire mess and go fishing.
A small video of the new aerators running. I think I like having both the power stream aerator in the front and the nozzle for the rear live-well, due to its depth.
