MikeyArriva
- Mar 28, 2012
- 96
1989 Arriva 2050 Mercruiser 5.0 Alpha 1 Gen 1
Sooo I'm just throwing this out here, I can't find anything in the search. So I just changed out the bellows and shift cable.. Apparently I missed tightening the transom side of u joint bellows because it was still leaking. When I took outdrive off too see why it was leaking, it was full of gear oil. Thats when i gave up and took to marina. They said that i didn't tighten transom side of bellow enough and that yoke and seal were worn. So they fixed that. I put er in the water tonight for a test. No leaks, Idled so smooth at the dock and slow cruising out of the area. Put her up on plane, ran amazing for a few minutes and then could feel a shake. I slowed to turn around and it didn't seem bad, when i put the throttle down it would barely plane. I pulled the throttle back and it shook, I could see a little bit of smoke coming out around the outdrive. Oil pressure was good on gauge. When i put throttle down again almost nothing happened. Wind going in the opposite direction i had to keep it going. I ran just above idle back but saw a marina and headed that way. Could feel a shake to the dock then it shut down. I couldn't get it to fire up again. just kept rollin over. Finally a half hour later i got it to fire up to get to launch but it was shakin and spitting and stalled again. In 7 years I have never had a problem with this engine. Could this be multiple miss fires or some major issue I can't think of? Def seems to be in the engine. I don't know where to turn now
