Took the boat out on the mississippi today, near grafton illinois.. I had fixed my dash grounding issue last night and all of the gauges seemed to be working correctly now, including the depth finder (which had been flaky up until now). In my confidence that the depth finder was working, I briefly went outside the channel markers while cruising along at about 25mph (depth finder said it was 29ft) until the boat sudden came to a smooth stop, I killed the throttle and turned the engine off quickly.
So there I sat, with immediate thoughts of outdrive damage. I put the outdrive into trailer position and put on my sandels before taking a shallow step into the 18" deep water. I felt around the leading edge of the lower unit and nothing seemed to be damaged, the prop looked fine, it was just missing a little more paint. When I spun the prop by hand it was so jam packed with sand I couldn't really tell if I'd damaged anything. I shoved the boat off the sand bar and walked into deeper water, jumped in, fired it up, and drove off.
I think I dodged a bullet. I decided to cut my day on the water short in case some damage had been done, and navigating a river with a defective depth finder had already caused an issue so I headed back to the ramp. Upon getting the boat out of the water all I can see is a few more abrasion marks on the bottom of the keel from the sand, and the bottom 3rd of the outdrive is now a really dull black. So, I'll put a replacement depth finder at the top of the priority list!
The only other time I ever ran aground was on one of my jetskis, same river, and that time it was mud, which really sucked.
