ran aground and now trim and tilt out???
Heyitsespo
Ok a few weeks ago I ran aground with my 2000 Oceanpro 90. Couldnt tilt the motor up but managed to get out and as soon as I was free the unit worked. Went out a few more times and ran aground again, same thing happened. Got free and no response from the tilt and trim. Ran a few minutes, motor tilted for a few seconds when I trimmed it out and quit. Still dead. Checked and relays are clicking from cowl switches. Hard to tell if they are clicking from the throttle controls since I'm too far away to hear it. Haven't checked motor voltage or jumped wires yet as I have to go back to the boat at the Marina and havent had a few hours to get to it. What could be damaged from running aground or the sudden deceleration to cause it to go out? I cleaned the contacts on the relays while out on the water and tried all connections. I let everything cool and ran in reverse thinking something got jammed or out of whack but no luck. I know the voltage is good because my ampmeter gauge and the one on my GPS both show charging. The release valve is a royal pain in the ass but thats my next option...release it and move the motor then tighten it up and try it. I'm at a loss on this one...oh and please no smartass remarks about running aground, the Great Bay in South Jersey can be a ***** at low tide.
Chris1956
Honorary Supreme Mariner
PTT units are designed for running aground. I would not think you damaged them electrically when you hit bottom, but you could have damaged them mechanically. Check especially the main connector from the PTT motor to the relay box.
BTW, I have almost the same motor, and boat in Barnegat. We hit bottom all the time.......
