So I ran my 305 crate motor that had 17 hours on it very low on oil.:mad-new:
There is a non-threaded hole in the bottom of the plastic timing chain cover (Most likely for a sensor for GM truck). My boat does not require this sensor hole.
The crate motor came with a flimsy plastic shipping plug that when I asked an auto mechanic what I should do, he said use that plug and gasket silicone to hold it in with. I was a little unsure but being a Carpender asking a professional mechanic his opinion, I wasn't going to argue.
Well.... 17 hours into a perfectly running motor the plug let go at cruising speed (2500 RPM) for a very short period of time before I noticed there being a problem and shut motor down .
I opened the engine cover to see the plug and most of the oil in my hold. I towed the boat to the nearest Shoreline and drove to the closest automotive store and bought a frost plug that fit the size of the sensor hole with oil.
I thought I might've done little to no damage as I caught the problem right away but when I put the frost plug in and filled it back up with oil, I took it out and now makes noise under load (getting up on plane)
I did a compression test and everything checks out on the top end. plugs look good and got a even compression at about 180 on all 8.
I'm thinking it's main bearing and crankshaft that let go. Anyone else have any other opinions on what the common is on running to 305 low on oil before I start buying parts and pulling motor out???
To top it all off, the previous boat owner must have disconnected the audio alarm for the oil/overheating as I might've shut the motor off a few seconds earlier if the audio alarm went on.:mad-new:
:mad-new:
PS
This is a freshwater boat
PS
