Raising an engine to insert a new freeze plug
BDM Boating
I have a 1997 Mercruiser 5.7 with a Freeze plug that poped out because I am stupid and didn't stick a wire in the drain hole. The plug is located directly over the engine mount on the front of the engine. I need to raise the engine about an inch to insert a new plug. What would I need to remove other thatn the two mounting brakets on the front to lift the engine?
I hope that the block did not crack internally but I need to get the new plug in to verify.
Or does anyone have an idea on what type of tool I could use to insert a new brass plug. It will slide in the space and will give me the room to fit something the size of a flat head under the plug.
JustJason
Re: Raising an engine to insert a new freeze plug
you'd need to pull the drive if your thinking about moving that motor even 1/8th of an inch.
meesh
years ago we used to use rubber expandable plugs much like a plumbing plug. You put them in and tighten the nut. They were ONLY EVER INTENDED to be temporary for EMERGENCY ONLY and I have not seen them in a long time. If you can find one you can get it running without much labor and see if you got lucky. Unfotunatly if you pushed a plug out from freezing I think your going to find water in your oil when you do get it running. Hope it turns out OK for you.
180shabah
The rubber plugs are still available, just getting harder to find. It would be a perfect solution here. Plug the hole, then you can test block integrity before doing any hard work.
JustJason
you can get the rubber plugs at napa.
180shabah
Looks like they just got easier to find.
wca_tim
funny... I still have three of them in different sizes in my "road trip" tool box... good call - perfect solution here...
BDM Boating
Thanks guys. Yes I had already purchased the rubber plug with brass fittings along with the standard brass plug that should go in the hole. The issue I am having is that the plug poped out directly under the engine mounting. So the the rubber plug is a little to tall to slide between the mount and the engine. This is what spurred the question about raising the engine slightly so that I could slide the rubber stopper in.
I can slide the new brass plug in but would need a tool that is curved on the end (Like a long screw driver with a 45 degree angle on the tip) to tap it in.
mkast
Use two 2x4's across the gunwales.
Attach a chain hoist, lift until engine weight is off the engine mount.
Remove engine mount, install core plug.
