Texasmark
- Dec 20, 2005
- 14,926
Re: raising 15hp outboard on transom using wood spacer (with pics)
My Merc manual says if compression is below 120 expect problems.....in addition to the even pressure statement.
To each his own, but if that were a 14' flat bottom john then it might pop up. That is a lot of boat for a 15. I had a Mirror Craft 14' with the hull shaped as yours and ran a Merc Mark30 (30 HP) on it with a side console. It ran out real nice. I had an 18 rude I used to run on 14' boats when a teen and it may have gotten to 22ish mph. 6mph smells of trouble. You might get a cheap tach and see where your rpm's are at WOT. That would speak volumes.
Mark
Thanks for the reply. I have checked the compression on my own...it was 90psi in both cylinders, which from my understanding is ok since they are about the same. Would the cavitation plate being below the bottom of the boat by 1.5 inches cause it to bog down?
Mark
