Hello, somone in the Bayliner forum successfully to seal the fishwells in his Trophy http://www.baylinerownersclub.org/forum/showthread.php?t=32024. I tried to post to ask some questions there, but it seems I am locked out of that forum eventhough I have not even post anything there yet! So I'll do it here.
So anyone here attempted the same thing? I did go to the Trophy dealership and looked at the new 2102 models and did see the latch and gaskets on the fishwells. The member in the Bayliner forum gave the part number of the gasket and the Southco latches that he found. I called the Trophy user support number in Arlington, Washington, and was given the following part numbers for the latch and the gasket:
Latch: 1848217 or 848217 (I can't read my own writing), gasket: 1701821
Anyway, the latch might be the same as the Southco (I ordered the latches from Southco). But the gasket used by Trophy is from a different manufacturer. The gasket cited in the Bayliner forum is from Taco Metal, and it seems to be more robust. But I got my gasket from Trophy. Although I got all the parts. But I probably will not try to install them until I have more time later on this summer, or fall. So we will see.
