Radio issues
weezzell_5400
I'm not new to wiring radios at all ...but this one has me stumped ....its a 1999 chaparral 1930ss ....the radio is a standard pioneer from walmart ....I know the 3 power wires being black red and yellow usually for ignition ....so that the radio comes on when the key is on.....well I can't seem to get power from what I assumed was the ignition wire..yellow...and there is also a orange wire that I can't get power from.... anda blue and white.I know what that one is for....all the other wires are speaker wires...can anyone help me on these wires....there was no radio in the boat when I got it...and can't seem to find a wiring diagram specific enough
unless you have a battery switch, tie the red and yellow together to a switched power source. that way your battery wont be dead in a few weeks
boat wiring is standard [h=2]American Boat and Yacht Council Standards[/h]
BlackGroundNegative / Neutral Main Return
Blue-StripeTilt up and or trim outTilt and or trim circuits
BrownAlternator Charge LightGenerator Terminal or Alternator Auxiliary Terminal to Regulator
Generator ArmatureGenerator Armature to Regulator
PumpsCircuit Breaker or Switch to Pumps
Brown w/YellowBilge BlowersCircuit Breaker or Switch to Blower
Dark BlueCabin & InstrumentCircuit Breaker or Switch to Lights
Green or Green w/Yellow StripeBonding SystemGrounding Wires (if insulated)
Green StripeTilt down and/or trim inTilt and or trim circuits
GreyNavigation LightsCircuit Breaker or Switch to Lights
TachometerTachometer Sender to Gauge
Lt. BlueOil PressureOil Pressure Sender to Gauge
OrangeAccessory FeedAmmeter to Alternator or Generator
Common FeedDistribution Panel to Accessory Switch
FeedAccessory Circuit Breakers or Switches
PinkFuel GaugeFuel Gauge Sender to Gauge
PurpleIgnitionIgnition Switch to Coil & Electrical Instrument
Instrument FeedDistribution Panel Electrical Instruments
RedInstrument FeedDistribution Panel to Electrical Instruments
Power FeedsPositive Main Power (particularly un-fused)
TanWater temperatureWater temperature sender to gauge
YellowGenerator FieldGenerator to Regulator Field Terminal
Yellow w/RedStarting CircuitStarting Switch to Solenoid
COLOR ITEM USE
