I have an issue that I hope someone can help with.
Equipment:
1990 Johnson 155 Commercial Outboard Model J155WTXESM
Apelco Model VHF 4500 Radio
Symptoms: With the motor running, radio broadcast has loud interference. Reception is fine. Dash voltmeter indicates batteries receiving 17+ volts at idle.
With motor stopped, radio broadcast is loud & clear.
I suspect a charging system component - rectifier/regulator.
Can someone assist in giving me a debug methodology?
Thanks and Best Regards,
Mike
Equipment:
Mike
