radio dies when lights on
FREDSDOG
i have an1989 larson san marino at night when i have the cabin lights on the more i turn on the dimmer they get then the radio volume goes down any ideas onwhat the problem could be. also would any one know where i could get wiring shematics for my boat any help thanks :confused:
Wstahl
Re: radio dies when lights on
I would say that you have corrosion in the wiring some where. This will cause a high resistance in the power circuit. As you need more power (current) when the lights are turned up it is not available. This will cause the voltage to drop to your accessories. That would cause the lights to dim and the volume to drop. It is basically the same as a low battery in your car. If it is low and all you have on is the radio (engine not running) everything is fine. As soon as you turn on the headlights the radio volume will go down. Hope that helps. Now all you have to do is find the point of high resistance.
Or you may simply have a battery that can't handle the load (too small) or its on its journey to "battery" heaven.
