racking my brains
leeray
i cant get my 85 force to run cleaned the carbs i have spark and gas dont know if it is enough will start some times for about 5 seconds and then dies is back firing out the exhaust some times seem to get it started for a little bit when i choke it also have gas dripping out of the carbs after you let of the choke the fuel pump looks good as near as i can tell
leeray
Re: racking my brains
hi there just thought i would let you know i found the problem it was in the ignition switch thanks for the help
