kpkeller88
- May 31, 2013
- 5
I have a rack and pinion steering system on my boat. The steering went from stiff to almost unable to move. I removed both the rack and pinion end and the end connecting the the i/o unit. The cable runs back to a nut and a threaded shaft with a rod that runs out of it. Does this threaded shaft seperate from the cable? My hopes are to spray some lube into the cable and work it back in forth to try to free it up. I have the rack side elevated and I sprayed some lube into the unit but I'm unsure if it would travel into the cable casing.
