quirky 1998 200 hp johnson outboard
bgbsshntr
I am mechanically inclined, however very little knowledge of 2 stroke motors. The motor starts fine, idles fine, goes into gear add idles through the no wake zone great, As soon as I jump on it it just dies. I have learned by frustration that if I put it reverse and floor it, put it back in forward and jump on it she pops on plain like a sunken bobber. I then have no trouble the rest of the tournament day unless I am catching and do not use her for a couple of hours. I have not done anything yet, but was wondering what yall thought and were to start. I plan on replacing all fuel lines and bulb due to reading other threads about todays gasoline being hard in the fuel lines. Thank you for any of your responses.
bgbsshntr
Just as a side note, the oiler is disconnected (add oil to tank at fill up) and it is carbureted.
Faztbullet
Try bumping the key when planning and if it helps the intermediate jet needs changed as there was a TSB on this covering several years models.
dingbat
First, take the anti-siphon valve out and throw it as far as you can.
Next, Install a piece of clear fuel line, preferably after the fuel pump, and check for an upstream air leak.
I had similar issues when my fuel got below 1/8 tank. Changed all the fuel lines and removed the check valve. No problems since
bgbsshntr
since I am changing the fuel lines anyways, I will get rid of the anti-siphon. It will be awhile before I can try the key bump because I am in Ohio. I will go ahead and rebuild the carbs and change the intermediate jet and just be done with it. Thank you both for your replies. Two tournaments last summer I lost my starting area due to this problem.
Before you toss the anti-siphon valve understand that it's there for a reason. They're required (by US Coast Guard regulations) if any part of your fuel system is below the top of the fuel tank. If there's a leak of any sort it will prevent fuel from filling your bilge and causing a very dangerous situation.
bgbsshntr
Here is an update on this motor. Did all previous mentioned, it stopped dieing and would jump on plane early in the day, load live well and then maybe it would get ot not, always eventually get up. Over the winter broke carbs all the way down to check the reeds, added a water separator (as recommend in so many forums). Get out this season was worse getting on plane and when I did get up to work a new problem started, she started surging. Third time out she detonated a piston. Bought a rebuilt power head paid to have it replaced, carbs gone through by the mechanic. Trying to break it in and won't go over 2000 rpms and misses. Did a 7/16 spark test, ordered a coil, (waiting on it as we speak). Now hear is my question: the cylinder that detonated on old power head is now fouling plugs but passed the spark test (cylinder#3) cylinder#4 is getting the coil. Could this be the power pack probably causing all my issues from the get go? I am tapped out on money and don't want to blow my new power head. I hope someone here can help I really miss my boat.
Faztbullet
Index flywheel and test ...possible pack,timer base or shifted flywheel hub magnet.
bgbsshntr
Thank you, talked to a friend and he has the same motor but it is a 225. We will swap these three parts one at a time, and see which it is. Marine motors are awesome when they are running good lol, but drive me nuts trying to pin point an issue. To dang expensive to just swap parts until you get it. Thank you for the advice.
bgbsshntr
While swapping out the parts we found that my timer base was sticking. We went ahead and put his ignition system on my motor to no avail. We did notice by looking at the plugs that different plugs would carbon foul at different start ups and runs. I wish we would have put his stator on my motor, ( it was getting late) but figured out that my timer base had stator sticky goo on the plastic ring. I figured this out the next day. I see were there is two streams of the goo on the inside of the stator. I have ordered a new stator, can this be the cause of the erratic miss and problems I have described?
bgbsshntr
The battery charges good and the tach works, the voltage is is at about 14 at idle then peggs when running at higher rpms
cfauvel
I think you need some diagnostic tools....multimeter, DVA adapter and jumper wires....CDI electronics..
does this motor have a carb per cyl? if so then I would venture to guess that the ONE carb is running lean....
a couple of tests.
1 - you can move the powerpack to the other side (unless this model is a single pack)
2 - you could move the carb to another spot and see if the dryness moves to new location (unless this motor has different jet sizes per carb)
it is NOT normal to for the voltage of the regulator to be 14v at idle and shoot way higher than that above idle....
once you get your test tools, test the stator, timer base, and powerpacks as per manual and as per CDI electronic's guides.
I think you have multiple problems....did you check the magnets in the flywheel...they must not be loose and evenly spaced...
bgbsshntr
Yes one carb per cylinder. The carbon fowling does not stay on one cylinder, it moves. Put on a good power pack timer base and flywheel from my buddies motor. Carbs were rebuilt by a tech when he swapped the power head. The stator is definitely going bad. I am going to test the rectifier per the manual. I have read on one of these that a bad stator can cause erratic spark when it heats up but give a good spark test cold
cfauvel
a bad stator is bad...it will manifest itself in ALL kinds of ways.....and possibly damage powerpacks, timer bases, and voltage regulators....and yep COULD run fine at idle, but trying to run at speed and it falters.
please get back to the forum if/when it is fixed..
bgbsshntr
The new stator will be here tomorrow. Parts are expensive. Wish I could afford to just replace the whole ignition system
cfauvel
^^ I hear ya...but with a small investment in tools, you may not have to replace parts unnecessarily .
oh and grounds on the power packs...make sure they are good and not broken under the heat shrink wrap....bad grounds are not good for obvious reasons.
bgbsshntr
By the way, I work maintenance and am an HVAC tech. The only thing I don't have yet is a dva to attach to my multi meter
cfauvel
let us know how it goes and whilst the flywheel is off check the magnets being secure....
bgbsshntr
I will keep updating. Flywheel is good to go. No magnets have moved, and center magnet is still on the mark
