I have 1997 a 30hp Merc Jet Prop on a 16 ft Bassboat. It has been sitting idle for several years until I picked her up. Gave it a quick tune up - plugs, new oil, fuel filter.... I put the key in and turn to on and a constant beep, beep, beep, beep..... happens. I did not even try to start it yet. Kill switch is on Run. It could not be low oil injection or overheat as I have not even had it running yet. I figure it has been sitting a few years so maybe a sensor is frozen. Try to start, she cranks but does not start. Put key in on position and still a constant beeping. I put gas directly in carb, figuring maybe some old gas left in there, she cranks, fires up and as soon as the gas I put in is gone she dies. Contstant Beeping again with key in on position. Next thought is kill switch is bad so I overide it, still the same beeping noise and will not start.
any idea's? I went to a local marine shop and the response was "30 hp Mercury Jet - that's an odd engine. Probably your oil injection preasure is low". I explain I have not yet tried to start the engine, key is in the on position. Response -" bring it in for $100 we can take a look at it". Does not fill me with a lot of confidence.
My next step was to replace the actual kill switch but before I do I wanted to find out if anyone has any other idea's.
Thanks
TK
Thanks
TK
