quicksilver 3000 classic controller
cuda440
Does anyone have the wiring diagram for the quicksilver 3000 classic controller. Purchased a different motor - a 1998 40 Hp merc. - and this is the controller that is with it. Only problem is they cut the wires from the throttle controller joining the ignition and all the switches. Help
seabob4
Re: quicksilver 3000 classic controller
Basically the same as the classic before the 3000. You should have 3 wires together, red, green, and blue, these are for the trim/tilt switch. They should mate up with wires coming out of your engine harness at the helm end. You'll also have 2 yellow/red stripe wires which are your neutral safety switch wires. They also mate up with the like pair in your engine harness...
