Re: Quickie for Dhadley
Fireman,<br /><br />Be sure to let us know what you decide and what happens when you test it. You've tried a lot of stuff. Looks to me like a new prop is in order.<br /><br />Personally, I still think the 10x11 is going to work for you, but that's just my opinion. Dhadley obviously knows a lot more about this than I do.<br /><br />I'm just working from my own experience with a 35hp on a boat of similar size. Mine spins a 10x13 stock OMC prop, right up to the rated RPM.<br /><br />You have a 25hp motor with the same prop pitch and diameter. It doesn't reach rated RPM. Same-sized boat, although you haven't described the type of hull or weight.<br /><br />Will the 10x11 get you up to rated RPM? I don't know, to tell you the truth, but I'm certain it will get you closer than you are now, as I've suggested before.<br /><br />You're not racing this boat...you just want it to run closer to its rating and get out and go fishing. It's not a critical thing, and you're not going to destroy your outboard, regardless.<br /><br />Since you're going to replace the outboard after this season, I'd just grab a reasonably-priced aluminum 10x11 prop, mount it, put the old prop in the boat as a spare and get out on the water.<br /><br />Once you get your 50, then it'll be time to fine-tune your system for maximum performance. Right now, I'd be going for maximun usability and minimum stressing out on this. But that's just me.<br /><br />Time to go fishing.
